Activity › Forums › Broadcasting › Beta SP to Mini DV
Beta SP to Mini DV
Posted by Bob Schniztzer on January 22, 2007 at 12:35 amI have a beta SP tape that I need to transfer the footage to a digital format. Is there a way to run it into my mini DV cam and record it from a beta SP deck? Would S-Video work?
Rob Forsythe replied 19 years, 8 months ago 2 Members · 3 Replies -
Rob Forsythe
January 22, 2007 at 1:36 pm[finalcutpro78] “Is there a way to run it into my mini DV cam and record it from a beta SP deck?” Yes (see below).
[finalcutpro78] “Would S-Video work?” Yes, again, great way to do it.
The “yes” is conditional to IF your camcorder HAS an “input” function.
Some do, many do not.What brand and model do you have?
One way to check is to put the camcorder in “VTR” (playback) mode, but do NOT press “PLAY”.
Connect your BSP’s S-Video cable into the camcorder’s S-Video output (yes, OUTPUT).Play a BSP tape and see if the image pops up on your camcorder’s LCD or viewfinder.
If so, connect the AUDIO from your BSP into the camcorder’s audio outputs (yes, OUTPUTS).If you are a broadcast pro, you can (or can FIND someone who can) get the proper cables and adapters to make that all work.
You’re ready to make your dub by putting the camcorder into “Record” and playing the BSP.Post back if you have more Q’s.
Bob Schniztzer
January 22, 2007 at 3:46 pmThe Beta deck is not hooked up to a computer (FCP) AND it does not have an S – Video output 🙁
Rob Forsythe
January 22, 2007 at 5:16 pm[finalcutpro78] “The Beta deck… does not have an S – Video output :(“
You can still use the composite connections in the way I described earlier (just hook the BSP composite out to the camcorder’s composite (yellow) output jack.
Composite will not give you as “clean” a transfer as “S-Vid” or component, but it will certainly work for many applications.
(I don’t know what you’re trying to do.)
But from your posts, it seems that you may not be experienced/comforable enough technically to make the proper connections (especially for audio, which can be a problem due to such big differences in LEVELS from “pro” gear to “non-pro” gear.)
We still don’t KNOW if your camcorder can even PERFORM an input dub.
If its too much hassle, as was suggested, pay someone with the proper gear to make the dub for you.
