Activity › Forums › Apple Final Cut Pro Legacy › Beta SP to FCP
Beta SP to FCP
Posted by Mike Debbie on February 6, 2008 at 6:12 pmWhat do I need in order to hook up a Beta SP to my Intel Power Mac to have timecode and deck control full deck control?
David Cooke replied 18 years, 6 months ago 7 Members · 7 Replies -
Shane Ross
February 6, 2008 at 7:55 pmA capture card.
http://www.aja.com AJA I/O, I/O LA, Kona LS…all standard def. Or prepare yourself for HD by getting the Kona LHe.
http://www.decklink.com Decklink Extreme, Multibridge Pro. Both HD ready.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Del Chapple
February 6, 2008 at 8:19 pmI’d go with AJA, Blackmagic still has not fixed the NTSC Component A to D side of theit multibridge so i’d assume the decklink has the same problem.. PAL is fine though..
del
you cant hear my inner voice scream… can you..?
Esther Leonard
February 6, 2008 at 8:21 pmHey MD! I’m actually going through that exact process at the moment, I’ve hooked up my beta sp deck (sony bvw 75p) with an addenda rosetta stone usb/4 9pin remote (for deck control) and getting video signal through firewire canopus box, seems to be workin pretty good, you’ll need to create a new A/V setting for deck control though.
Hope this is helpful,
Esther -
Walter Biscardi
February 6, 2008 at 8:27 pm[Esther Leonard] “and getting video signal through firewire canopus box, seems to be workin pretty good, you’ll need to create a new A/V setting for deck control though.”
This does work, though keep in mind you are limited to the DV codec when you do this. If you use an AJA product, you can workin 8 or 10bit uncompressed which is really preferred for BetaSP originated material.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Del Chapple
February 6, 2008 at 8:31 pmYes!! Listen to walter!! DV is highly compressed and the canopus box is composite!! Listen to walter!!
del
Chris Borjis
February 6, 2008 at 9:28 pm[del chapple] “I’d go with AJA, Blackmagic still has not fixed the NTSC Component A to D side of theit multibridge so i’d assume the decklink has the same problem..”
what are you talking about specifically?
component analog input and output is fine on the multibridge extreme.
composite output is awful and un-useable, is that what you mean?
David Cooke
February 6, 2008 at 9:50 pmWe have a Kona LHe card at the facility I work at it works “perfect”. If this is within your
price range.
1VideomilkmanD’s Video
