Activity Forums Compression Techniques Beta Sp to DV
  • Beta Sp to DV
    Posted by Todd Mcmullen on May 8, 2007 at 6:57 pm
    I am attempting to archive and clone a large amount of Beta Sp tapes to the digital world.
    (Approx 140 tapes)
    Other than Digibeta, what would a good cost effective format be.
    Obviously, the less compression the better. would DV cam be preferred over dvcpro 50?
    I also need to keep the original timecode from the master.
    Is there another format I am missing?
    thanks
    Todd McMullen
    Flip Flop Films
    Austin
    http://www.toddmcmullen.com
    Daniel Low replied 19 years, 4 months ago 3 Members · 6 Replies
  • Daniel Low
    May 9, 2007 at 10:24 am
    Depends on what you’ll be wanting to use the footage for. Personally I’d capture them to a high quality but efficient codec, usually one that will come with your capture card and leave them in just a digital form on some quality external drives.
    No more tape, totally non-linear access, playout to whatever format you need…
  • Ed Dooley
    May 11, 2007 at 4:10 pm
    DVCPro-50 is much better than DV (CAM or otherwise). It’s twice the data-rate. Photo J-PEG at 75% is pretty good too. We do some projects that originated on Beta in the DVCPro50 codec and it looks great.
    Ed
  • Daniel Low
    May 11, 2007 at 4:47 pm
    DVCPro50 uses a colour subsampling of 4:2:2, same as PhotoJPEG at 75%. PhotoJPEG at above 75% is 4:4:4, so much better.
  • Ed Dooley
    May 11, 2007 at 4:55 pm
    But 4:4:4 color sampling translates into huge file size, and it won’t be any better
    quality when you start with Beta-SP, which isn’t 4:4:4. As an analog format it translates
    roughly into 3:1:1. Putting it into a 4:4:4 color space doesn’t do anything for the quality.
    Ed
  • Todd Mcmullen
    May 14, 2007 at 1:13 pm
    What is a Formula for hard drive space ie…
    1 30 minute betaSp digitized dvcpro50 equals ? gigs..
    thanks
    Todd McMullen
    Flip Flop Films
    Austin
  • Daniel Low
    May 14, 2007 at 1:46 pm
    DVCPro50 is 50Mbits/second.
    https://www.rorke.com/avcalc/calculator/RDAVStorageCalculator.swf
    Be careful not to confuse bits and bytes (8 bits to each byte)
