Activity › Forums › Apple Final Cut Pro Legacy › beta sp to DSR20 VTR using S-video link
  • beta sp to DSR20 VTR using S-video link
    Posted by Jermaine Cameron on June 8, 2009 at 1:43 pm
    Hello
    I have dubbed some footage from Sony Betacam SP to mini DV but got some terrible jagged edges around moving objects in the footage. I know this is common on this type of interlaced format but these jagged lines are worse than normal.
    I used a PVW2650P beta deck to dub the footage onto a DSR20 VTR for mini DV using an S-video link. When played back on the original beta master the footage is perfect but when I log the mini DV preview in FCP these jagged lines appear.
    Does anybody know what the problem may be or have any suggestions?
    Kind Regards
    J
    Jermaine Cameron replied 17 years, 3 months ago 3 Members · 4 Replies
  • David Bogie
    June 8, 2009 at 5:28 pm
    > [Jermaine Cameron] “I have dubbed some footage from Sony Betacam SP to mini DV but got some terrible jagged edges around moving objects in the footage. I know this is common on this type of interlaced format but these jagged lines are worse than normal.
    It’s not normal at all. You’re making an interlaced dub of interlaced material. Should work peachy. Possibly your playback or captured clips from the DV are set improperly. Try placing one in a timeline and using item properties and a change filed order filter to see what happens.
    bogiesan
  • Arnie Schlissel
    June 9, 2009 at 4:30 am
    [Jermaine Cameron] “but when I log the mini DV preview in FCP these jagged lines appear.”
    How does it look on your NTSC (or PAL) monitor? Don’t look at FCP. Turn the computer monitor to the wall. Only look at your NTSC (or PAL) monitor. FCP does not display video at full quality on your computer monitor. Nor does it display interlaced video on your computer monitor. This is why the FCP manual has several pages showing you how to hook up an NTSC (or PAL) monitor.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jermaine Cameron
    June 9, 2009 at 4:57 pm
    Hi Sorry for the late reply guys had a long night and day shift! It plays fine in A PAL external monitor on both the original copy and the dubbed DV tape.I’ll have a play around with the manual using your advice tonight.
    Thanks guys
  • Jermaine Cameron
    June 10, 2009 at 3:11 pm
    Hi Guys
    It turned out fine when I actually captured the clips in FCP. because it was it was the full footage I didnt want to waste time logging clips then capturing, so I thought I would ask first. Thanks for all the help.
    Jermaine
