Activity › Forums › AJA Video Systems › Beta SP into Kona 3
  • Beta SP into Kona 3
    Posted by Spiguet on November 19, 2007 at 8:09 pm
    I’ve come from Avid Adrenaline production land and moved into FCP without knowing much about the hardware involved. I have just put a Kona 3 card & K3 box on the system and need capture from a Sony BetaSP UVW-1400A. Adrenaline handled all source formats in, this Kona only has SDI in. Furthermore, the deck has RS-232C remote and the Kona has RS-422. Now what?
    Jeremy Garchow replied 18 years, 10 months ago 7 Members · 17 Replies
  • 17 Replies
  • Walter Biscardi
    November 19, 2007 at 8:15 pm
    AJA has converters for Analog Component to SDI along with embedded audio. We use the HD10AVA as this converts both SD and HD into the unit.
    As for RS-232, no idea on that one.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Gary Adcock
    November 19, 2007 at 8:58 pm
    [spiguet] ” I have just put a Kona 3 card & K3 box on the system and need capture from a Sony BetaSP UVW-1400A. Adrenaline handled all source formats in, this Kona only has SDI in. Furthermore, the deck has RS-232C remote and the Kona has RS-422. Now what? “
    Adrenaline may have handled all of your SD formats but the HD Adrenaline has the same connections as your Kona Card (and analog audio i/o)
    Either an HD10C2 D>A converter or an IoLA could be added to your system to handle the analog SD content.
    You will need to use a Keyspan connector to control the RS232 via USB
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Spiguet
    November 19, 2007 at 9:49 pm
    The Io connects to the Mac via Firewire, is there any need to have the Kona card? What is the point of the capture card if the Io box connects firewire?
    Seth
  • Walter Biscardi
    November 19, 2007 at 9:57 pm
    [spiguet] ”
    The Io connects to the Mac via Firewire, is there any need to have the Kona card? What is the point of the capture card if the Io box connects firewire?”
    The Io is SD only.
    The Kona 3 is SD and HD. It provide SD to HD Upconvert, HD to SD Downconvert and 720 to 1080 Cross Convert.
    I’m assuming you need the HD capabilities of the Kona 3 and that’s why you got it.
    Read my Blog!
  • Erik Hansen
    November 19, 2007 at 11:59 pm
    Gary should have said Io (not IoLA) as you can use the Io as a standalone converter to (SD) SDI. The Io has composite, S-video, component and SDI inputs that can all be output to it’s SDI output to the Kona card.
    The IoLA only has analog outputs, unless you use it as designed though firewire.
    If the Io, is used as analog converter you should also be to use the Io Control panel to tweak color, hue, saturation, etc… I don’t remember all the options.
    – Erik
  • Gary Adcock
    November 20, 2007 at 1:06 am
    [erik hansen] “Gary should have said Io (not IoLA) as you can use the Io as a standalone converter to (SD) SDI. The Io has composite, S-video, component and SDI inputs that can all be output to it’s SDI output to the Kona card.
    The IoLA only has analog outputs, unless you use it as designed though firewire.”
    I stand corrected.
    gary adcock
    Studio37
  • Szumlins
    November 20, 2007 at 2:09 am
    As Walter and Gary both said, you want one of each of their recommendations:
    An AJA HD10AVA will take your analog component and 4 channel audio and give you an SDI out with embedded audio
    An AJA ADA4 will take 4 of your AES channels and convert them to analog audio for print to tape (Kona 3 already has Component output)
    A keyspan 232 to 422 adapter will give you device control.
    With these three tools and the Kona 3, there really aren’t many formats on the planet you can’t ingest, up/down/cross convert, and output to.
  • Bob Zelin
    November 20, 2007 at 4:16 am
    you said that you come from AVID Adrenaline production land. How the hell were you controlling your UVW-1400 with the Adreanline ? Didn’t you have the Addenda adaptor on this VTR to convert 232 to 422 (the Adreanline or ANY AVID product never had an RS232 interface).
    Bob Zelin
  • Walter Biscardi
    November 20, 2007 at 11:01 am
    [Bob Zelin] “Didn’t you have the Addenda adaptor on this VTR to convert 232 to 422 (the Adreanline or ANY AVID product never had an RS232 interface).”
    Just looked up on Markertek and found this RS-232 to RS-422 adapter. Only $30.
    https://www.markertek.com/SearchProduct.asp?item=LT%2DRS%2D2%2F3&off=6&sort=prod
    Looks like what is needed here.
    Read my Blog!
  • Spiguet
    November 20, 2007 at 1:38 pm
    Bob,
    I was at a different post-facility with the Avid (you actually setup the suite) and now I’m at a company doing in-house stuff. They had an Adobe setup where they routed everything through the UVW-1400A and captured it live via RCA inputs without any remote control. They bought a Final Cut Studio system but it didn’t have a capture card. We have an Sony XLH1 camera and want to move everything HD, so I ordered the Kona3 card & K3 breakout box. I anticipated that the breakout box would handle component, composite, s-video, etc., but that is not the case. I messed that up.
    So now, I’ve got this Kona3 and cannot capture from my beta, even without using remote. I could dump the beta source to DV and bring it in, but I’m doing some keying and don’t like DV for green screen stuff. Should I just get the Aja Io and forget the capture card, then I’d settle for HDV out of the camera for the HD instead of using the HD/SDI.
    Seth
