Activity › Forums › Apple Final Cut Pro Legacy › Beta sp ,fcp 5.0.4 , Kona lhe workflow
  • Beta sp ,fcp 5.0.4 , Kona lhe workflow
    Posted by J on September 4, 2006 at 5:44 am
    Hi
    anyone have any gotchas about working with betasp deck into Kona Lhe with FCP 5?
    usually work in 8 bit timeline but if anyone has any ideas let me know .
    the final is all SD no HD out put.
    Chris Poisson replied 20 years ago 3 Members · 2 Replies
  • Walter Biscardi
    September 4, 2006 at 2:37 pm
    Just make sure you know how to use the Kona Control Panel in case you need to set anything up there. But as long as you use the AJA Easy Setups in FCP, everything is all set up for you automatically.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Chris Poisson
    September 4, 2006 at 3:16 pm
    I have an LH and a UVW 1800, the only gotcha I see is sometimes the audio gets lost, so you have to go into playback settings and set it back to Kona.
