Best Workflow…
I’m editing a :30 spot. Since renting an uncompressed FCP suite for the entire edit is not in the budget, I was planning on renting a suite for the capture and output only in order to obtain the best quality. I plan on capturing the source footage from Beta SP using a Cinewave I/O set-up (using the cine YUV 8-bit codec) directly to a firewire drive. Then moving the edit over to my Dual 2.3GHz G5. I could then download the Cinewave codec to the G5 in order to work with the footage in an uncompressed timeline and then after the edit was completed rent the Cinewave suite agian and print my master back to Beta SP for air. Is there a more efficent workflow and should I expect adequet performance from the G5 while editing on my system? The show has very little graphic elements and is pretty straight forward (very little effects, transitions, filters, etc..)
-chris
