Activity › Forums › Apple Final Cut Pro › Best Workflow to Create a PAL DVD from FCP X
Posted by Jeff Krieger on July 27, 2013 at 2:21 amI need to go from HD in FCP X to a PAL DVD. I have Compressor if needed. What is the best workflow. Someone please help. I can’t find anything, and I’ve been looking a while. Thx.
Jeff Kirkland replied 13 years, 1 month ago 3 Members · 3 Replies -
Jeff Kirkland
July 27, 2013 at 8:42 amThe simplest is to duplicate the project, change it’s properties to be a PAL SD DVD compatible format, then share as a DVD.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Ronny Courtens
July 29, 2013 at 10:13 amI’m afraid when you duplicate an edited NTSC Project you won’t be able to change the Project Settings of the duplicate to PAL as you cannot modify the time base of a Project once it has media inside.
But you can create a new Project using PAL settings, then copy/paste the content of the NTSC Project onto the PAL Project.
I must say I have pleasantly been surprised with the way FCPX conforms NTSC video to PAL on the timeline. The Rate Conform tool works extremely well, even using the basic Floor settings.
Jeff Kirkland
July 29, 2013 at 10:38 amWhat he said 🙂
