Activity Forums Adobe After Effects Best Workflow Practice – Not Re-using Images from a Large Library
  • Best Workflow Practice – Not Re-using Images from a Large Library
    Posted by Matt Cheah on December 25, 2012 at 1:04 am
    Hey guys,
    Quick question. I have a client who’s requesting that I make a fairly long minute motion graphic with a few hundred different images. Do you guys have any efficient solutions to make sure that I don’t use an image more than once? Thanks!
    Matt Cheah
    Classy Deer Productions, LLC
    http://www.ClassyDeer.com
    Roland R. kahlenberg replied 13 years, 9 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    December 25, 2012 at 1:37 am
    With the Project Panel active, select File>Consolidate All Footage to remove duplicate copies of footage items. If you’re about to archive the AEP, you should follow this routine with File>Reduce Project. Take note that this latter step requires you to select Folders/Comps/Footage that you want to archive. Of course selecting a higher hierarchy object selects all encapsulated objects.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
