Activity Forums Adobe After Effects Best workflow for time remapping
  • Best workflow for time remapping
    Posted by Scott Silvia on September 14, 2011 at 9:20 pm
    I am using a Canon 60D to shoot mainly music videos and some action sports shots. What is the best way to achieve the smoothest realtime to slow motion effet. Should I shoot at 60fps, 30fps, or 24fps to achieve the shot that begins at 2:47 of this video:
    https://www.youtube.com/watch?v=kh29_SERH0Y&ob=av3e
    Scott Silvia replied 15 years ago 3 Members · 3 Replies
  • Ben G unguren
    September 15, 2011 at 1:03 am
    If you want slo-mo you need to shoot at the highest frame rate possible — so if 60 is the highest you have, then 60 is what you should take….
    If you’re editing at 24fps, then you will be able to slow your footage down to about 40% of real-time, all the while having a specific image to provide for each frame of the movie.
    If you learn how to use Timewarp, you could slow down your video to 20% of real time (the filter would morph/generate every other frame). For some shots, you can slow it down even more, but the slower you get, the more Timewarp needs to be customized and tweaked to produce satisfactory results….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Walter Soyka
    September 15, 2011 at 12:57 pm
    I agree with Ben.
    If you shoot at 60fps and deliver at 23.976, you can simply re-interpret [link] the original 60fps footage at 23.976 for an instant and perfect 40% slowdown.
    For particularly challenging slow motion shots, I like Twixtor Pro. It offers object separation through multiple mattes, and manual point and spline guidance.
    Walter Soyka
  • Scott Silvia
    September 21, 2011 at 8:42 am
    Are the shots, in the video I posted, that go from real-time to slow mo and back to real time in 24fps or 60fps?
