Activity › Forums › Adobe Premiere Pro › best workflow: dv to premiere to ipod to hdtv
  • best workflow: dv to premiere to ipod to hdtv
    Posted by Jack Laurie on May 16, 2007 at 3:36 pm
    What is the best way to go from capturing dv thru premiere pro to ipod and then to an hdtv . I mean compression schemes, settings(sa resolution) and work flow.
    thanks,
    Jack
    Vince Becquiot replied 19 years, 4 months ago 3 Members · 2 Replies
  • Harm Millaard
    May 16, 2007 at 4:29 pm
    DV is 720×480, I don’t know what the iPod is, but significantly less, possibly 360×240, and then you want to enlarge that to 1920×1080?
    I hope you have a sufficient supply of headache pills, because it will be disastrous.
  • Vince Becquiot
    May 16, 2007 at 5:40 pm
    Keep it at 720×480 for the HDTV playback. No point in upscaling if everything is in standard def.
    As for the Ipod, the resolution is 320 x 240 I believe.
    Your best (cheap) bet here is to purchase Quicktime pro.
    You can export from Premiere at 320 x 240 using the Quicktime animation codec if you want to keep an optimum quality and keep it small. Or you can export at 720×480 and let Quicktime Pro do the scaling.
    Either way, you’ll need a third party encoder (such as QT Pro) for the conversion to iPod format.
    Cheers,
    Vince
