Activity Forums Adobe Premiere Pro Best workflow – check in/out system
  • Best workflow – check in/out system
    Posted by Zach Meissner on June 29, 2010 at 7:37 pm
    Here is the scenario: We’re using the CS5 Master Suite.
    At work, another editor and I are using iMac’s to edit video projects – I know. (they’re the late 2009 dual core models)
    We have a drobo to save all the files to. We’re connected to it on a gigabit connection, but only connected to the network at 100 Mbit.
    We need a system in which we have folders locally on our computers that we bring down from the Drobo to work on, and that are synced on the server so that the other editor can use the project files at the same time, and to make sure the most up to date version is on there.
    Need a system where we can check in and out projects. Much like how Dreamweaver works.
    Is there a software out there to accomplish this?? It doesn’t have to be anything complicated, just need a good folder sync, and check in/out solution.
    http://www.lab316.com
    Zach Meissner replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
