Activity Forums Adobe After Effects best way to wrap a still of sky around 360
  • best way to wrap a still of sky around 360
    Posted by Scott Depace on February 1, 2013 at 12:39 am
    Is there a good way to make a high resolution still wrap 360 degrees around to simulate a sky? To be more clear, half of a sphere to place over a 3d layer project in after effects, so as a camera pans I have a background.
    Todd Kopriva replied 13 years, 3 months ago 3 Members · 2 Replies
  • John Cuevas
    February 1, 2013 at 1:22 am
    Couple of ways to do this. If you are working CS6 you can create an environment layer. Press Cntl+K and click the advance tab and change your Renderer to Ray Traced 3D. Drop the layer into your comp, right click on the layer and choose environment layer.
    Or Create a new comp and add a camera. Drag in your layer and go to Effects>Perspective>CC Environment.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Todd Kopriva
    February 1, 2013 at 5:20 am
    I show how to make an environment layer here:
    https://www.video2brain.com/en/lessons/environment-layers
    After Effects team blog
