Activity › Forums › Boris FX Particle Illusion › Best way to use PI 3.0
  • Best way to use PI 3.0
    Posted by Dane Silzle on October 12, 2005 at 4:16 am
    I have Motion 2 combustion 3 and AE 6.5 . I work in OS X Panther and Tiger
    I have been using you particles in C3 but it is very slow.
    I am Looking for the most logical way to work with your particles
    and to have access to your updated Library of new particles.
    Like your stand alone idea and am considering it.
    Does PI 3.0 offer a 3D environment I noticed that you have a demo with
    a star that goes around the animated figure ?
    Can I do this / use this with After Effect 6.5 or Motion
    and create a 3D motion around a object?
    What would be the best way to go……..
    Dane
    Aharon Rabinowitz replied 20 years, 11 months ago 3 Members · 2 Replies
  • Elvis Deane
    October 12, 2005 at 9:33 pm
    pI3 is still a 2D program. The example you mentioned is really just a trick of having two copies of the same emitter on two layers, hiding particles on the upper layer, and making the ones on the lower layer visible. There’s a tutorial about it here:
    https://www.wondertouch.com/tutorials/around_01/around.htm
    It’s really just a masking trick, so you should be able to do it in any program that has multiple layers and mask/matte tools.
    Many of the version 3 emitters are now available for Combustion by the way, though since your problem is with the speed of C3, that may not factor in to your decisions.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Aharon Rabinowitz
    October 17, 2005 at 2:55 am
    Wondertouch also offers emitters for Motion.
    Also, AE and pIllusion work very well together, easily exchanging positition data.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
