Activity Forums Apple Final Cut Pro Legacy best way to upres 480i to 1080i60
  • best way to upres 480i to 1080i60
    Posted by Anhtu Vu on July 12, 2011 at 4:07 am
    A client asked me to add a 2 min scene coming from an SD sequence 480i to my existing timeline in HD 1080i60.
    ideally i would like to copy the content of his SD sequence to my HD sequence in case the client want to make changes but FCP upres look pretty bad. Would it be better to output the SD sequence to Beta then redigitise using the Kona scaling ?
    Bret Williams replied 15 years, 2 months ago 4 Members · 3 Replies
  • Shane Ross
    July 12, 2011 at 4:18 am
    Digibeta would be better. But yeah, that, or Compressor with all the settings set to BEST.
    Shane
  • Sascha Engel
    July 12, 2011 at 5:29 am
    I did use the SD to HD plug in from Red Giant a couple of times and the result was pretty good.
    Sascha.
  • Bret Williams
    July 12, 2011 at 3:07 pm
    If you have After Effects, it will give you the best results and be very quick. Especially with interlaced.
