Activity › Forums › AJA Video Systems › best way to transfer DigiBeta SD to ProRes 422 ?
  • best way to transfer DigiBeta SD to ProRes 422 ?
    Posted by Tc Yamada on September 22, 2010 at 2:33 am
    Hello, I am new to the AJA IO world, new to the machine room all together. screwed? help me Cows!!
    The network dumped a huge pile of SD DigiBeta tapes on us and we need to get them into our ProRes workflow.
    I am renting equipment and realize I am probably missing something big.
    Any help from you Cow heroes (you are heroes of the universe btw) is much needed/appreciated.
    Here’s what I have come up with:
    DVW a500 Digi Deck >> AJA IO HD >>> MBP >>> SATA (express card slot) >>> G-Drives
    Here’s my Question(s):
    The DigiBeta tapes are all SD, the AJA box will convert them to ProRes 422?
    is this upres going to look alright?
    is the setup of the Deck>>AJA IO especially complex or can I figure it out with manuals and forums?
    am I supposed to run this through FCP?
    I want to use my MBP (2.33GHz Intel Core 2 Duo, 2GB 667MHz) –keeping the newer towers for editing is this gonna work??
    Thanks guys!
    Tc Yamada replied 16 years ago 4 Members · 5 Replies
  • Michael Sacci
    September 22, 2010 at 5:55 pm
    [Chip Yamada] “The DigiBeta tapes are all SD”
    That is kind of redundant, there is nothing but SD DigiBeta tapes.
    [Chip Yamada] “ProRes 422”
    That is just a codec, what are you looking to go to, SD, 720p or 1080i or p?
    If up-converting you need to set the correct cropping if you source material is 4:3, if it is anamophic 16:9 it is an easier path.
  • Jeremy Garchow
    September 22, 2010 at 6:15 pm
    Have you ever hooked up a capture card and deck before? You said you have a machine room?
  • Tc Yamada
    September 28, 2010 at 12:24 am
    For anyone who needs to go from DigiBeta to ProRes 422 on a MacBook Pro, here’s the deal:
    Digibeta deck (Sony DVW A500) via SDI/BNC (audio follows video) to AJA IO HD box (hardware conversion to HD–firewire800 to MBP), Final Cut Pro will recognize the AJA and you can choose the in/out codec of your dreams, Log and Capture, Sonnet Tempo Express 34 SATA card to external drive (or express card firewire 800 if you like).
    *Don’t forget to install the drivers and updates for the AJA and Sonnet express card.
    *you need to use the express slot because the AJA going into the 800 port maxes the firewire bus, and USB 2 not recommended for HD throughput.
    So I answered my own question and just did selects off a troughful of digibetas with fine results. I hope this helps someone someday.
    Peace.
  • Nick Price
    September 28, 2010 at 2:26 pm
    HI chip,
    what were the results like? Did the quality look acceptable, considering its never going to look like filmed HD? Would be interested to know if this would make a difference if a digibeta shot film would look better as HD if an HD projector were available for screening.
    thanks
    nick
  • Tc Yamada
    September 28, 2010 at 3:53 pm
    I was impressed by the upres quality, but I am no expert. The IO HD hardware conversion was definitely better than FCP rendering.
