Activity Forums Apple Final Cut Pro Legacy best way to share media between projects?
  • best way to share media between projects?
    Posted by Michael Johnson on July 5, 2005 at 2:12 pm
    actually, “safest way” would probably be the better question. if i capture footage for one project, and then want to use some of that same footage in another, what is the safest way to get it into the new project? i could import the files individually. or i could drag a bin from one project to another, too. my fear comes when i go to uprez. because clips in two projects are pointing to the same files, when i uprez the clips in project A, how will FCP react to those clips in project B?
    if i’m looking at this in entirely the wrong way, then i’ll gladly receive a smack upside the back of the head. but i’d like some guidance on how to handle shared media.
    mike
    Matthew Brunn replied 21 years, 2 months ago 2 Members · 1 Reply
  • Matthew Brunn
    July 5, 2005 at 7:02 pm
    Just make the clips offline in the project you are redigitizing. Then digitize your new footage.
