Best way to secure 3.5mm cables?
Posted by Ken Jones on August 3, 2013 at 4:03 pmI shoot primarily with a Nikon D800 DSLR. I have a Shure FP33 that has two 3.5mm jacks for stereo Tape Out and Monitor In. I use the XLR outs to record to a Tascam DR-40. The 3.5mm Tape Out feeds the D800 audio in, and the D800’s headphone output feeds back to the FP33 3.5mm Monitor In. Amazingly, I get a very clean audio recording on the D800. So good that I rarely ever feel the need to use the recording from the DR-40. That’s the system overview, but here’s my question:
Does anyone know of a good way to secure the 3.5mm cables into the mixer and camera? I never seem to have a problem with the cables slipping out on the camera end, but the 3.5mm cables pull out of the FP33 mixer all the time.
Bill Davis replied 13 years, 1 month ago 4 Members · 8 Replies -
Ty Ford
August 3, 2013 at 4:39 pmHello Ken and welcome to the Cow Audio Forum.
Well, plugs and jacks do have standards, but I have seen one a bit bigger or smaller.
Question is, is it the FP33 jack being slightly too big or the plug being slightly too small……
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford’s Blog -
Ken Jones
August 3, 2013 at 4:51 pmThanks for the quick response Ty.
My initial thought is that the FP33 jacks are too large. I have tried other brands of 3.5mm plugs and they all slip out just as easily. Do 3.5mm jacks have a “retaining spring” like 1/4″ jacks do? I wonder if there is way to open up the FP33 and tighten the 3.5mm jacks?
I was also hoping that maybe somebody knew of some kind of external clip that could be used to clamp the 3.5mm plugs tight in the jacks.
Ty Ford
August 3, 2013 at 6:29 pmYou might try to contact Shure customer service.
https://www.shure.com/americas/support/service-repair
I’ve found them to be very accommodating over the years. Or, if you’re handy popping the hood, go on in for a peek.
Regards,
Ty Ford
Ken Jones
August 3, 2013 at 6:46 pmThanks Ty. I just sent them an email. I’m thinking that maybe a particular brand of plug might fit tighter. I will see what they say.
Craig Alan
August 3, 2013 at 7:50 pmYou might try a mini-plug extender. Not only have they solved that problem for me but it made it easier to plug in and out because it’s off the device and takes some of the pressure off the plug, particularly if you velcro or gaffer tape it to a strap or whatever. It does however add another connection to the chain and any of them can cause a problem. Make sure that the plug has the right number of bands around the connection that matches the others. You know, mono vs stereo.
Mac Pro, macbook pro, Imacs (i7); Camcorders: Panasonic AG-HPX170/AG-HPX250P, Canon HV30/40, Sony Z7U, VX2000, PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
Craig Alan
August 3, 2013 at 7:54 pmhttps://www.amazon.com/Female-Stereo-Reinforced-Premium-Quality/dp/B004LGRKZC
something like this. Ty will chime in if I’m wrong. In which case … never mind.
Ken Jones
August 3, 2013 at 8:42 pmI hadn’t thought about using a short M/F extension cable. That might actually do the trick. I could tie off the female ends to the PortaBrace mixer bag as a strain relief and then shouldn’t have to worry about the cable getting pulled out of the side of the mixer. My only concern is that adding more cables adds another connection point that could cause a problem.
I am going to wait for a reply from Shure to see if they recommend a brand of plug that has a tighter fit. If they do, I will probably have a custom cable made that has a pair of 3.5mm male plugs at each end.
Bill Davis
August 4, 2013 at 4:27 amOr just buy some right angle adaptors like the Calrad 35-484-A Right Angle 3.5mm Stereo Male to Female and use them in conjunction with the judicious application of gaffers tape.
FWIW.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
