Best way to screen HDV pal footage in theatre?
Hi all,
I was advised to cross-post this one over here. I got some good advice over at the FCP forum but if I can avoid installing QT 7 and just screen my film via FCP it would be ideal:
I’ll be screening a 23min documentary at a theatre in a week. It’s not a real cinema, but a large theatre with a beamer. The film was initially made for the web but I’d like to make a sharp looking version for the screening as well. Now I can’t decide whether I should make a standard def DVD, or just play it from my laptop. It was shot at 25fps with a HDV Canon AHX1, downgraded on import to Apple Prores 1440×1080. So my questions are:
-If I make a DVD, what are the best export settings? Through Compressor to MP2 or straight out of FCP as is?
-Let’s say I just play it from my MacBook Pro; could I do this through FCP (View-external video-all frames) with optimal sharpness or would it be recommended that I export a proper QT movie? All of the different export settings/options are driving me mad…
-What are the pros and cons of each method?Thanks in advance,
MagnusMacBook Pro 15inch, 2.4 ghz Intel Core i5, 4gb RAM, FCP 7.0.3
