Activity Forums VEGAS Pro best way to render movie
  • best way to render movie
    Posted by Chris Nickila on May 22, 2009 at 5:38 am
    I am wondering if someone could give me some advice on exporting a file to dvd format. I am working on a video that will use a lot of chroma key effects along with many individual jpeg backgrounds and audio. It will probably be about 20 to 25 minutes long. Here is my question. Should I save the movie out in sections first into mpeg 2 and then add them all back into a progect together? I ask because I am wondering if too many effects may cause a problem when redering it. I have a duo pentium 2ghz with three gigs of memory and is running vista.
    Wayne Anderson replied 17 years, 1 month ago 3 Members · 3 Replies
  • Graham Bernard
    May 22, 2009 at 6:21 am
    The biggest issue with DVD creation is the amount of visual noise apparent on the finished pre-DVD burning.
    Much has been written on this here, and over on the main SONY Vegas site. If you really need the noise to be kept, then a high bitrate is required to read that throughput of data being decoded back to the viewing screen. More noise the higher the bitrate and/or the ways in which that bitrate is also prepared.
    I would say that unless you have some very demanding visually-noisy content throughout your DVD and/or you haven’t allowed for this in the encoding then you should be fine. In any event, when I am doing a piece of work I often make a DVD-RW test DVD to just confirm this.
    So, with this understanding I would say you really don;t need to separate out your files. Just do it. BUT, this is what I also do: I also create a pre-render AVI to give myself the option of locating any issues that might happen IF I was to go directly to MPEG. Once I have that pre-render AVI I know it WILL render in something quicker than real time – PLUS I would know it works!
    Now, from here, I then produce the files for the DVD:
    MyFile.mpg – this will be the VIDEO only MPEG2 file
    and the;
    MyFile.ac3 – this will be the AUDIO only AC-3 file
    I put these in the same folder and from this folder I create the DVD. Both files in the same folder. Both files with the SAME PREFIX name – MyFile.
    So, to recap, unless you have majorly visually noisy content, and then you can change through Average and Constant bitrate variation, PLUS making a pre-render and then the 2 file option, you should really be good to go.
    If I have missed something out I am sure somebody else will step in.
    Just get that AVI done and then the 2 files and test on a DVD-RW. That’s the way I do it.
    Grazie
  • Chris Nickila
    May 26, 2009 at 6:03 pm
    Thanks this is very helpful.
  • Wayne Anderson
    August 18, 2009 at 5:46 pm
    Just noticed your post on audio and wonder if you are still out there as I have a question regarding this subject. I have always done the rendering the way you recommend and it works great for making a DVD. However lately I have been uploading my movies to Motionbox.com and they prefer the MPEG format. Unless I include the audio when I render there will be no sound when I upload. My question is what difference will there be if I also make my DVD from that file instead of having to do a separate AC3 file. Since I am just working in stereo it wouldn’t seem to me to make a difference. Thanks – Wayne
