Activity Forums Canon Cameras Best way to record some voiceover?
  • Best way to record some voiceover?
    Posted by Kevin C. on August 26, 2006 at 10:10 pm
    I have an audio technica mike and could record to mini DV.
    But is there a good option to record straight to hardrive?
    That’s where it ends up anyway.
    thanks
    G5 – MAC 10.4.7
    Scott Hatkow replied 20 years ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    August 27, 2006 at 4:39 am
    Continue to use the camcorder and tape it to DV,
    You’ll have a time-coded back-up that you can store,
  • Craig Alan
    August 27, 2006 at 4:30 pm
    Yes. There are USB interfaces that allow you to plug in mics and there are USB mics that plug in directly. One advantage to recording on your cam is you have a visual reference of what was recorded. On the other hand, most camcorders do not have audio components as good as dedicated equipment.
    August 29, 2006 at 12:10 am
    [eyecamiam] “On the other hand, most camcorders do not have audio components as good as dedicated equipment.”
    Having been in this business for a few decades, I can tell you that the audio section in the cheapest digital camcorders is leaps and bounds better than the finest analog studio gear that used to be considered state-of-the-art.
    Under 98% of “finished product” mixes, the camdorder audio will be just fine.
    If you need better than that, you wouldn’t have a mic and studio facilities at your disposal at this end of the spectrum anyway.
    That’s why, all things considered, the “record-to-camcorder” audio method is likely the better option.
  • Scott Hatkow
    September 2, 2006 at 7:52 pm
    Hey again Kevin, also a little trick I use (I agree, use the cam) Figure out your dialogue and take your cam and mic and go sit in a car/truck/van in a closed garage. Automobiles have pretty good sound deadening built in and a closed garage adds to that. I haved used this technique many times and people have asked how I did it! Easy easy.
