Activity › Forums › Adobe After Effects › best way to output different versions
  • best way to output different versions
    Posted by Anhtu Vu on February 9, 2011 at 12:17 am
    My 5 sec logo animation has been approved by the client. This Logo will be used for TV, DVD, Bluray in various flavors ( 1080i/p, 720p and NTSC ). I want to deliver the best quality possible and catering to different format without the need to convert thus lowering its quality.
    My intention is to output the same logo in: 1080i and p, 720 i and p and NTSC.
    what’s the best way to achieve this ?
    Since my original Comp is in 1080i@ 29.97, should i save as a new project then change the comp to 720 and proceed the same for ntsc.
    how about frame rate, should i output in different frame rate also ?? If i understand correctly, changing frame rate of an image without altering its format ( 1080, 720…) is a simple matter of reconforming which should not affect image quality at all.
    Kevin Camp replied 15 years, 7 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    February 9, 2011 at 8:33 am
    Resize the 1080 comp in the Output module – as far as frame rate conversion, this was recently posted on the cow:
    https://library.creativecow.net/harrington_richard/Converting-Frame-Rates/1
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Anhtu Vu
    February 9, 2011 at 4:42 pm
    This logo is all generated within AE ( text, animation flares…), i’m not importing any footage with a define frame rate so there no need for frame rate conversion.
    I guess my original question was not clear. Basically, I was asked to design a logo for a company, the Logo will be used on all their film, which of course, includes a variety of format.
    The Logo has been approved, now i need to deliver the mov to them. There was no precise instruction from them other than give us the best quality possible. So i thought of giving them the same Logo in ( 1080, 720, 480 ) but i’m not sure at which frame rate, it does not make sense having to output every existing frame rate for each format. Suggestions ??
  • Anhtu Vu
    February 9, 2011 at 5:31 pm
    Actually my question is more about which frame rate should i deliver my mov. As for sizes, i got it covered by just taking my original comp (approved version in 1080) and duplicate it, then change its preset to the output size i want ( 720 and NTSC ).
  • Kevin Camp
    February 9, 2011 at 10:18 pm
    i suppose you could stick with the common standards…
    broadcast (for ntsc/atsc):
    – 1920×1080, 59.94 fields per second
    – 1920×1080, 29.97 frames per second
    – 1280×720, 59.94 frames per second
    – 720×486, .91 par, 59.94 fields per second
    for bluray you could add:
    – 1920×1080, 23.976 frames per second
    for dvd you could add:
    – 720×480, .91 par, 23.976 frames per second
    – 720×480, 1.2 par, 23.976 frames per second
    – 720×480, 1.2 par, 59.94 fields per second
    if you wanted the most flexible single format that a graphics guy/gal could use to create anything they needed for broadcast/bluray/dvd/web then there’s a non-standard format that you could use:
    1920×1080, 59.94 frames per second
    with the largest frame and the highest frame rate, some body like myself can make that into 1080i, 720p60, 480i really easily – 24p would be a bit harder.
    however a wacky frame rate like that won’t jive well in nle’s and many other applications, so it would really depend who’se getting the file…
    if you wanted a smaller selection, i’d choose 1080i60, 720p60 and a 480i60 (.91 par/4×3). those are probably the most common. anyone working in widescreen sd, can probably handle the hd files correctly, so the 4×3 version is just for someone stuck with a really old nle or need to deliver 4×3 for whatever reason.
    if you wanted to add a 24p (23.976) version, go with 1080p24… again, i’d assume that anyone working with 24p would be able to handle the the 1080 frame size. 1080p24 can also work quite well for pal time lines (it’s quite easy to conform 24p to 25p).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
