Activity Forums Adobe After Effects Best way to make a node based flat comp which undulates (possibly use Plexus?)
  • Best way to make a node based flat comp which undulates (possibly use Plexus?)
    Posted by Craig Hellen on December 10, 2016 at 7:29 pm
    Hi guys
    So I have a trangular node based piece of branding from a client and we want to do 2 things.
    1)
    Have a gentle wiggle applied to the “mesh” and have all the nodes and lines stay connected.
    2)
    Be able to pull a camera in (or just scale to get the effect) to have icons placed in each node point.
    There are 2 screens which I hope help illustrate this:
    I do have plexus but I don’t know if we can get it to behave as a flat layer and be able to navigate to and keep the camera focused on different points.
    Any help is appreciated!
    Craig
    Co-Director Podchains Ltd
    Video Producer / Motion graphics designer https://bexmedia.net
    Matthew Keane replied 9 years, 8 months ago 3 Members · 2 Replies
  • Greg Gesch
    December 11, 2016 at 11:23 pm
    Hi Craig, how do you want the mesh to look when it undulates/wiggles? It might be something as simple as using the Bezier Warp effect (or any of a number of effects in the Distort menu) you might also look at the Puppet tool. For the zoom, as you say, you can just scale up and pan & scan. As long as you are using vector graphics they will remain crisp – are you having a particular problem?
  • Matthew Keane
    December 14, 2016 at 10:28 am
    That triangular mesh does indeed look very plexus-like. If you recreate your mesh using 3D Nulls at the same Z position, Plexus will give you a flat mesh of connected nodes (depending on the Plexus renderer you choose). You can add a noise effector for a gentle undulation (only in the XY axes, if you prefer) and then move the camera around it as you wish, so yes, it should work.
