Activity Forums Adobe After Effects Best way to handle HDV footage?
  • Best way to handle HDV footage?
    Posted by Robert Altman on December 17, 2007 at 1:25 pm
    AE doesn’t deal well with HDV (or any other MPEG-2) format, so I was wondering what workflow works best–(I’m on a Mac)
    1)Export footage in a non-GOP format (such as Apple ProRes) from Final Cut Pro to AE
    or
    2)Export footage as HDV from FCP, and let AE make a low-res proxy?
    HDV has great image quality, but it definitely wasn’t designed for post!
    –Robert
    Darby Edelen replied 18 years, 8 months ago 3 Members · 4 Replies
  • Kevin Camp
    December 17, 2007 at 1:54 pm
    exporting to any codec that does not use temporal (interframe) compression and that uses a very good (high quality) intraframe compression or none at all would be the way to go…
    -apple’s animation codec with no compression keyframes (default) is usually a good way to go.
    -image sequences may be better, offering 16bpc files (tif, tga, png, pict).
    -photojpeg is a lossey codec, but at high quality settings (90-100) you’ll be hard pressed to see any image degredation and you’ll save a lot of drive space, if that’s a concern.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Kevin Camp
    December 17, 2007 at 4:26 pm
    prores, as you mentioned, may also be a decent choice. it does use lossey intraframe compression, but no temporal compression, similar to photojpeg. they both use 4:2:2 color that is greater than the 4:2:0 color of your hdv, so you won’t lose color (actually, photojpeg drops to either 4:1:1 or 4:2:0 color at about 75% quality)….
    Kevin Camp
  • Kevin Camp
    December 17, 2007 at 4:30 pm
    oops, correction, photjpeg is 4:4:4 at 100%, 4:2:2 at 75%…
    Kevin Camp
  • Darby Edelen
    December 17, 2007 at 6:13 pm
    [Kevin Camp] “oops, correction, photjpeg is 4:4:4 at 100%, 4:2:2 at 75%…”
    I wasn’t even aware that JPEG used chroma compression. Learn something new everyday here on the COW (;
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
