Activity Forums Canon Cameras Best way to grab some audio
  • Best way to grab some audio
    Posted by Kevin C. on August 9, 2006 at 11:36 pm
    I’m director. If I need to grab some new audio dialogue, should I do it with my GL1 and my audio technica mike on mini DV, or would it come out just as good with my handheld mini disc recorder on MD? thanks
    Kevin C. replied 20 years, 1 month ago 3 Members · 4 Replies
  • Donald Berube
    August 10, 2006 at 5:37 am
    Something tells me that you may have slightly better mic preamps and audio leveling, in addition to more frequency range, on the GL1 than on the handheld mini disc recorder. It could be said that the difference between the two is negligible?
    The benefit of using the mini disc recorder is that you will have quicker random access to your sound bites (less time spent searching for gems)
    – don
    https://noisybrain.com
    https://www.bosfcpug.org
    https://fcpugnetwork.org
  • Thaxter Clavemarlton
    August 10, 2006 at 1:35 pm
    [Donald Berube] “The benefit of using the mini disc recorder is that you will have quicker random access to your sound bites (less time spent searching for gems)”
    But the benefit of shooting to DV is that it will already have Timecode, will be easier to capture, and can be stored with the other master tapes for future reference.
  • Donald Berube
    August 10, 2006 at 4:36 pm
    Exactly.
    I would record to the GL1 versus the mini disc.
    – don
  • Kevin C.
    August 11, 2006 at 12:15 am
    thanks guys, it’s so much faster to mini disc, than having to set up XLR converter, mike etc, but of course I’d have to convert the MD to CD (anologue maybe) as editors can’t input an MD.
