Activity Forums Maxon Cinema 4D Best way to get rid of internal edges of an object?
  • Best way to get rid of internal edges of an object?
    Posted by Dean Chapman on October 14, 2012 at 2:40 am
    Hey guys,
    I have an object with a million cuts (edges) throughout the shape.
    I’d like to simply get rid of all the internal edges, leaving a nice whole object.
    I tried select the whole object and hitting melt….that didn’t seem to do anything.
    I didn’t have too much luck with weld either.
    Any suggestions?
    Attached is a pic, as well as the scene file.
    Dean
    4792_weldtest.c4d.zip
    Brian Jones replied 13 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    October 14, 2012 at 8:47 pm
    you want to remove the extra lines and leave just quads? I think it can only be done by hand. I’m guessing you used a fracture plugin of some sort on the object then removed pieces and Connect/Deleted/Optimized the remainder to make it one piece again.
    The only way I can think of to keep it clean is to fracture a copy of the object select the pieces you want to remove and Boole them from the original (make the pieces slightly thicker first).
