Activity › Forums › Adobe Premiere Pro › best way to export for dvd?
  • best way to export for dvd?
    Posted by Dan Leow on May 9, 2011 at 9:19 pm
    hi there.
    i have a 13 min clip that i need to output as dvd format.
    footage is 1920 X 1080 23.98fps ntsc
    i have tried match to settings and it comes up with a mpeg file but when i use encore to create an image file to later burn with imgburn – the quality is loss?
    just wondering whether anyone could give me some pointers about what settings are used for dvd exporting without losing quality??
    thanks
    Steve Brame replied 15 years, 4 months ago 2 Members · 4 Replies
  • Steve Brame
    May 9, 2011 at 11:05 pm
    Your source is HD, and DVD’s are SD, so quality loss is unavoidable. You cannot ‘match settings’ since there is no such thing as a HD DVD. Your DVD will be 720 x 480, period.
    At that short a duration though, you’ll be able to export to an MPEG2-DVD at a high data rate, around 8Mbps, make sure ‘Use Maximum Render Quality’ is checked, and make your ‘Quality’ setting ‘5’. We prefer CBR for programs that will obviously fit onto a single DVD encoded to the highest data rate.
    Here is an online calculator to give you a settings goal.
    https://dvd-hq.info/bitrate_calculator.php
    Steve Brame
    creative illusions Productions
  • Dan Leow
    May 10, 2011 at 6:36 am
    thanks for the response Steve. I just wondered if there was a way to shrink the high quality footage somehow onto a DVD.
    got my answer.
    thanks.
  • Dan Leow
    May 10, 2011 at 9:34 pm
    Just had another thought…
    ive seen tv series that shrink hours of shows on a dual layer dvd but the quality is quite sharp… does anyone know how this is done? is it using avi format?
  • Steve Brame
    May 10, 2011 at 9:48 pm
    No. DVD spec is MPEG2…nothing else.
    Steve Brame
