Activity Forums Media 100 Best way to edit from a DVD???
  • Best way to edit from a DVD???
    Posted by Roman Mykytyn on April 13, 2005 at 12:24 am
    I have a client who brought me a master on a DVD. He needs a few changes, slight inserting/deleting of material, then back out to DVD. I can always digitize it into M100 from a DVD player, but that seems silly, since the thing is already digital. I have ripped the DVD and gotten a .m2v file and an AC-3 file, but I can’t use DVD Studio Pro to edit even a little bit, so I’d have to convert the MPEG2 to M100 or whatever….!!!??!?!?!?
    It just seems like there’s a better way. Any ideas? How do others handle this situation?
    Roman
    Media 100 v.8.2.2
    Jose Panadero replied 21 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Marc Morel
    April 13, 2005 at 12:39 am
    You might want to look here : https://www.miraizon.com/
    I’ve tried once or twice, not enough to give an informed opinion but it did extract video as advertized.
    Hth,
    Marc
  • Jose Panadero
    April 13, 2005 at 12:02 pm
    Yo can try it with MPEGStreamClip, an OS X application that can demux vobs and export as quicktime files. It’s quick and free. I think you can download from http://www.alfanet.it/squared5/mpegstreamclip.html
  • Roman Mykytyn
    April 13, 2005 at 4:12 pm
    Thanks, drollo
    Coincidentally, I downloaded MPEG Streamclip yesterday and gave it a shot. It seems like it might work. The weird thing is, there are so many of these ripping programs and most of them just wouldn’t run on my machine! They installed OK, but when I double-click them, the icon zooms as if it’s starting, but that’s it. It never opens. I’m not quite sure what’s going on, because others have had success with them.
    I was able to get Mac the Ripper and MPEG Streamclip to run, but OS ex, Yade X, MissingMpegEdit and others just wouldn’t open up and run! Does anybody have any ideas as to why that might be?
    Roman
    Media 100 v.8.2.2
  • Jose Panadero
    April 13, 2005 at 4:52 pm
    We use MPEG StreamClip 1.2 on a G5 Dual 2GHZ, Media 100 HD 10.1 and OS X 10.3.8. Maybe you need to use Apple Software Update to update your OS and try to use StreamClip again. I think you can download an older version of MPEG StreamClip that maybe runs on your environment or try to delete the MPEG StreamClip preferences.
    The only thing that doesn’t work for me with StreamClip is exporting with Animation Codec. When I do this, if video levels are illegal, i get some “posterized frames”, but I use Media 100 Pal 720 or 844/X 8bit codecs.
  • Roman Mykytyn
    April 13, 2005 at 5:03 pm
    drollo,
    Thanks for your response. Actually, MPEG Streamclip DOES work for me. It was the others (OS ex, Yade X, MissingMpegEdit, etc) that wouldn’t run.
    The only problem I’m having with MPEG Streamclip is that it doesn’t show my M100 codecs as options in the pulldown menu for a Quicktime export. I know that my M100 is working otherwise, so the system apparently is aware of the codecs, but MPEG Streamclip can’t see them. Any ideas?
    Roman
    Media 100 v.8.2.2
  • Bob Russo
    April 13, 2005 at 7:47 pm
  • Jose Panadero
    April 14, 2005 at 8:35 am
    You can download the Media 100 HD 10.1 from the Media 100 website. Inside the .dmg file are included the Media 100 Codecs that you can install to use them.
