Activity Forums Panasonic Cameras Best Way to downconvert
  • Best Way to downconvert
    Posted by Waldo Chan on February 16, 2009 at 12:10 am
    I am asking the best way to make the downconvertion in order to keep best quality possible because I have an 1080 edition with panasonic hpx2000 and need to record at Standard def….
    1. solution is making downconvert through the aja Kona Lhe
    2. dragging the 1080 edition to a new 720 x 486 sequence inside final cut(no export needed).
    3. Exporting an uncompressed 10 bit 1080 quicktime and then import to 720 x 486 uncompressed 10 bit sequence in final cut.
    Thank you for your time..
    Waldo
    Shane Ross replied 17 years, 7 months ago 2 Members · 1 Reply
