Activity Forums Apple Final Cut Pro Legacy best way to do this?
  • best way to do this?
    Posted by Jason Harvey on July 9, 2007 at 3:05 pm
    Which is the best way to do this? —
    I am trying to convert Sony HDV1080i 60 to DV (FOOTAGE ONLY/ NO SEQUENCES STARTED) — so all my footage is in the same format.
    I know that I should have downcoverted on capture – but I didnt realize that I was recieving any other formats.
    So – whats the best way to do this?
    -Can I use compressor with no sequences?
    -QT conversion?
    or recapture the downconvert?
    Jeremy Garchow replied 19 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Chris Borjis
    July 9, 2007 at 3:09 pm
    use quicktime conversion.
  • Jeremy Garchow
    July 9, 2007 at 3:15 pm
    Recapture. It’s the best way to keep the tc integrity for further recaptures/onlines.
    Jeremy
  • Jason Harvey
    July 9, 2007 at 3:29 pm
    Thanks guys – I think Recapture is going to be the way to go –
    I just tried QT conversion – All audio is way outta sync.
    Now –
    FCP 5.1.4
    Shooting and Capturing through Sony HDR FX-7 >>HDV 1080i60 (1440×1080).
    -Set Camera up for DV out.
    -Change Easy Setup to DV Anamorphic.
    Now on my machine –
    When launching FCP it doesnt recognize the Firewire.
    If I continue and try to open Log & Capture…Instant Crash.
    (Works fine when Easy Setup is back to HDV)
    I think its just local to my main machine…I Successfully did it on another…Just a pain.
    I tried trashing Prefs and restarting…still no luck now what?
  • Jeremy Garchow
    July 9, 2007 at 3:34 pm
    Quit FCP, unhook your camera, set it up to downconvert to dv. Turn it off. Hook it up to the computer, Turn it back on. Launch FCP.
    Jeremy
  • Jason Harvey
    July 9, 2007 at 5:33 pm
    …Still quits on me everytime…
    I dunno whats wrong with it.
  • Jeremy Garchow
    July 9, 2007 at 5:42 pm
    Completely unhoook the camera. Does FCP launch then?
  • Jason Harvey
    July 9, 2007 at 6:27 pm
    Yes –
    FCP launches fine –
    It just does not recognize my FW control when the settings are changed to capture DV NTSC.
    AND
    If I attempt to open the Log & Capture window while in a DV setup I crash & burn.
    …works fine on another machine with the same settings and FW cable.
    Just stinks to transfer back to mine.
  • Jeremy Garchow
    July 9, 2007 at 8:03 pm
    Hmm, sounds like the settings are wrong on your FCP.
    Instead of logging and capturing, can you preview your footage OUT of FCP through the camera?
