Activity › Forums › Adobe After Effects › Best way to do this in 3D?
  • Best way to do this in 3D?
    Posted by Kit Carson on June 26, 2016 at 9:03 am
    I need to turn the 2d image into the 3d image
    Ive tried masking each section and rotating it in 3d but im finding it very difficult to make sure each section is on the correct axis and actually lining up.
    Jason Jantzen replied 10 years, 3 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    June 27, 2016 at 8:04 am
    Think of it as “L” shapes instead of stripes. This way you can create a series of square pre-comps with the L shapes inside and position them in a zig zag (as seen from the top) and rotate the L shapes within the pre-comps to match the desired design.
    You can also use the following plugin to arrange the layers automatically on a path:
    https://www.motionboutique.com/polyline-plugin/
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Jason Jantzen
    June 27, 2016 at 5:29 pm
    Have you tried Polyline? It basically sets this kind of thing up for you in a snap. It’s by Motion Botique and a pretty powerful little tool. https://vimeo.com/124596281
    Jason Jantzen
    vimeo.com/jasonj
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
