Activity › Forums › Adobe Premiere Pro › Best way to Deliver to PPRO
  • Best way to Deliver to PPRO
    Posted by Trinity Greer on February 14, 2006 at 2:02 pm
    HEllO Folks,
    I am an FCP guy and a client of mine is a Premiere Pro Guy. He would like to Output a project to his consumer camera for us as a projection copy. I f i burn him a QT apple DV codec will he be able to use that file in a Premiere timeline? if not what would be the best QT file to give him? Thanks for your help.
    Trinity Greer replied 20 years, 7 months ago 2 Members · 2 Replies
  • Dave Friend
    February 14, 2006 at 2:50 pm
    If you have QuickTime Pro (and I bet you do) then the best thing would be to use the QT and export it as an AVI using the DV/DVCPRO settings. He will be able to import this directly into Premiere as easily as you import mov files into FCP.
    He will be able to import and use the QT file type you propose but it will not be as clean or as fast as the avi would be.
    I was just wondering if QT Pro on the Mac has the avi export option. Does it, or is that only on the Windows version?
    Dave
  • Trinity Greer
    February 14, 2006 at 8:14 pm
    It does. Your post is exactly what I needed, Thank you for your help.
