Activity › Forums › DVD Authoring › Best way to convert an authored NTSC DVD to PAL?
  • Best way to convert an authored NTSC DVD to PAL?
    Posted by Khashyar Darvich on May 11, 2009 at 8:42 am
    Hi Everyone,
    We have an already authored NTSC DVD (both in a hard drive and DLT tape format).
    We are needing to also send the finished DVD to Europe and other PAL territories.
    What would be the easiest way to convert an already authored NTSC DVD (with menus, content, etc, to PAL).
    Is there a way to do an NTSC to PAL DLT tape conversion?
    Or, does the entire DVD need to be re-authored, but in PAL?
    By the way, the project was authored in Scenarist.
    Thank you very much for your help and feedback.
    Khashyar
    Roman Melekh replied 17 years, 4 months ago 6 Members · 17 Replies
  • 17 Replies
  • Khashyar Darvich
    May 11, 2009 at 10:24 am
    Hi Everyone,
    Just from looking a bit deeper into Creative Cow posts, it looks like we may have to re-build the Scenarist project in PAL.
    The motion menus where built in After Effects. Does anyone know if it is easy to convert After Effects motion menus to PAL?
    I have not spoken with the person who will be converting the AE menus, but I’m trying to understand it myself first.
    Thank you for your thoughts and feedback about the best way to convert the motion menus and other DVD elements into a PAL Scenarist DVD project.
    Khashyar
  • Roman Melekh
    May 12, 2009 at 9:32 am
    Re-render menus – this is simple….
    question is “how you can transcode your video”
    do you have 23.976 + pulldown or “original” 29.97 fps video?
    and – YES, you must re-author all from A to Z 🙂
    you can copy pre-post-cell commands from NTSC scenario to PAL
  • Max Kovalsky
    May 12, 2009 at 4:10 pm
    We do dual format projects all the time. We’ll typically author NTSC, export the script out of Scenarist, hack the script to make it into PAL and import it into a new PAL project. One you have your PAL scenario, just relink to the PAL assets. This way there’s no need to reauthor and re-QC the programming.
    Max
    Blu-ray producer
    New York
    Area4.tv
  • Roman Melekh
    May 12, 2009 at 5:28 pm
    …hack the script to make it into PAL….
    and how to hack 29.97fps video and subtitles? )))
  • Max Kovalsky
    May 12, 2009 at 5:47 pm
    You can’t. Gotta reencode the video and resize the subs. That’s what I meant by saying “relink to new assets”.
  • Khashyar Darvich
    May 12, 2009 at 7:22 pm
    Thank you both, Max and Roman, for your advice and thoughts about how to create a PAL Scenarist project from an NTSC version.
    Since the motion menus and video transitions were created in After Effects in 30 fps video, what is the easiest to convert those AE menu clips to PAL? Does AE have a fps conversion option? Should our DVD author use compressor? Or, will we need to convert the menu video files to PAL in the same way as our video feature and special features? (I know that the menu buttons will have to be replaced).
    Also, since the video clips for the NTSC Scenarist project were already digitized to Quciktime files, is there an easy way to convert them all to PAL? Is there software that can do this, or should I take the clips to a lab like Lightening Media in Los Angeles for the conversion. The most time-consuming way would be to reassemble the clips on a timeline, export them to tape, and have the lab convert the entire tape to PAL, and then redigitize each clip individually in the new PAL format, but that seems like the long way of doing this. Thank you for any suggestions for converting the QT project clips.
    Thank you for all of your thoughts and advice,
    Khashyar
  • Khashyar Darvich
    May 12, 2009 at 7:38 pm
    Hello again,
    I just received a message from our DVD author, and he said that he received a recommendation that he could use “visualhub” to convert the menus to PAL.
    Has anyone heard of how effective visualhub is?
    Thank you,
    Khashyar
  • Roman Melekh
    May 12, 2009 at 8:45 pm
    IMHO you can just set composition option to PAL@25, and re-render menus to PAL
    Video….you have 23.976+pulldown or native 29.97fps ?
    If you have 23.976fps videos, you can speed-up your video and audio without “Lightening Media in Los Angeles”…I know how to do this “hack” on PC/Windows – try to use Canopus ProCoder or Carbon Coder.
    Audio – any audio editor, you must to apply “time stretch” filter and speed up to 25 fps (multiply speed to 1.042709)
  • Roman Melekh
    May 12, 2009 at 8:47 pm
    …a recommendation…
    ufff….the best way is re-render in AE, but not convert “from-to”
  • Max Kovalsky
    May 13, 2009 at 12:02 pm
    ProCoder will do a good job transcoding from NTSC to PAL if you’re in a crunch.
