Activity Forums Adobe After Effects Best way to convert 30fps to 29.976fps and still keep sync?
  • Best way to convert 30fps to 29.976fps and still keep sync?
    Posted by John Slately on June 1, 2011 at 10:14 am
    I need to convert a video from 30fps to 29.976fps (DVD), and still keep it in sync with audio.
    Could someone tell me what is the best way to do this?
    Thank you!
    Todd Kopriva replied 15 years, 3 months ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    June 1, 2011 at 10:34 am
    UNtil you get a definitive answer, try slowing down both audio and video by 1%. Test this out on a 15-30 second segment before committing to the entire clip.
    Fingers Crossed!
    RoRK
    AE Training in South East Asia. AE templates for sale and rental. Click here for more
  • Kevin Camp
    June 1, 2011 at 2:23 pm
    this is pretty much the same as what roland said, but in a different way…
    if the audio is in the clip, try selecting the clip in the project window. then choose file>interpret footage>main and conform the frame rate to 29.97.
    drag that onto the make comp icon and ram preview portions of it to check the result. there may be a slight pitch change, but i’m not sure how detectable it would be.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    June 1, 2011 at 5:34 pm
    If the original poster actually meant 29.97, not 29.976 (which is no normal frame rate), then I have a small correction to make to Roland’s suggestion. The factor for retiming is 0.1%, not 1%. (29.97 is 30 * 999/1000, not 30 * 99/100.)
    Sorry for being the nitpicker. 😉
    BTW, there are some tips here regarding conversions like this, including using Time Stretch versus conforming to a frame rate in footage interpretation, depending on what you want to do with the audio (preserve pitch versus preserve synch).
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
