Activity › Forums › Apple Final Cut Pro Legacy › Best Way To Connect Two MacPro’s To One Drive
  • Best Way To Connect Two MacPro’s To One Drive
    Posted by Ben Mullins on July 6, 2012 at 10:54 am
    I’m running two MacPro-based edit suites and up until now I have not needed them to be connected to each other in any way, however this has changed and I would like to know the best way to do so. Basically I’d like one large RAID drive (12TB+) where all footage from all projects is copied to, which can then be accessed by both MacPro’s (simultaneously but not both working on the same project at the same time though).
    Any help is much appreciated.
    Ben.
    Ben Mullins replied 14 years, 2 months ago 3 Members · 4 Replies
  • Shane Ross
    July 6, 2012 at 5:54 pm
    COnnect the RAID to one of the units. Then connect the Macs via Ethernet. The Mac with the RAID connected…enable sharing on it…including DRIVE sharing.
    Shane
    Little Frog Post
  • Joseph Owens
    July 6, 2012 at 7:30 pm
    [Shane Ross] “Then connect the Macs via Ethernet.”
    Surely this isn’t as simple as plugging an RJ45 cable between the two….
    and if you come back with “… and stop calling me Shirley”, you are so written out of my estate….
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Shane Ross
    July 6, 2012 at 8:23 pm
    Between two machines, it is that easy. That’s how we are connected at one of my work locations, and we share media back and forth constantly.
    Shane
    Little Frog Post
  • Ben Mullins
    July 12, 2012 at 12:01 pm
    Thanks Shane, I have received the same advice from other sources too so I shall set this up. Thanks again, it’s a big help.
    Ben.
