Activity › Forums › Apple Final Cut Pro Legacy › Best way to color grade / correct on a laptop: FCP and Macbook
Rafael Amador replied 14 years, 9 months ago 3 Members · 14 Replies
Shane Ross
December 14, 2011 at 6:50 amRaf…I have the MXO2 and MXO2 Mini. You cannot do what you are claiming to do.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Rafael Amador
December 14, 2011 at 7:04 am[Shane Ross] “Raf…I have the MXO2 and MXO2 Mini. You cannot do what you are claiming to do”
Yeap.
I understand than feeding a Broadcast quality HDMI signal to the card you can get Broadcast monitoring. The problem is on the Mini Display/HDMI signal out of the Mac.
Rafael -
Shane Ross
December 14, 2011 at 8:27 amWhen you feed HDMI to the card…it is sending the signal to the COMPUTER connection…the Express34 connector. It doesn’t loop HDMI in to HDMI out…that’s not how it works. This is like a KONA card…BMD. It connects to the computer…you feed HDMI into the card…card connected to the computer via PCIe or Express34…FCP, Avid, Adobe…sees the signal. They send an HD signal OUT of the computer connection to the HDMI out. It doesn’t go HDMI IN to HDMI OUT.
Shane
Little Frog Post
Rafael Amador
December 14, 2011 at 1:02 pm[Shane Ross] “When you feed HDMI to the card…it is sending the signal to the COMPUTER connection…the Express34 connector. It doesn’t loop HDMI in to HDMI out…that’s not how it works. This is like a KONA card…BMD. It connects to the computer…you feed HDMI into the card…card connected to the computer via PCIe or Express34…FCP, Avid, Adobe…sees the signal. They send an HD signal OUT of the computer connection to the HDMI out. It doesn’t go HDMI IN to HDMI OUT.”
Got it it.
Is not the FC or Color signal, but the Finder.
rafael
