Activity Forums Creative Community Conversations best way to blend 24fps & 25 fps footage w/ one audio track?
  • best way to blend 24fps & 25 fps footage w/ one audio track?
    Posted by Sj Miller on September 2, 2015 at 4:22 pm
    Hi guys,
    I have an interview, seperate audio track, two angles. One camera recorded on 24 fps and the 2nd on 25 fps.
    Whats the best approach here? – Remove frames from the 25fps video?
    Bret Williams replied 11 years ago 2 Members · 1 Reply
  • Bret Williams
    September 2, 2015 at 5:26 pm
    The most important part is what format you have to deliver. If it’s 24p then put the 25 in a 24p. Or vice versa. Probably won’t even notice the drop (or repeated) frame since it’s an interview.
