Activity Forums Apple Final Cut Pro Legacy Best way to batch export?
  • Best way to batch export?
    Posted by Aaron Elkins on October 10, 2008 at 12:33 am
    What is the best way to export a set of sequences containing multiple video audio tracks?
    We have 3 separate video clips on each sequence for each angle. How can we have Final Cut export each track individually? Do we need to create a new sequence for each angle?
    Thanks in advance!
    David Bogie replied 17 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 10, 2008 at 3:19 pm
    [Aaron Elkins] “What is the best way to export a set of sequences containing multiple video audio tracks?
    You can’t export multiple tracks from the timeline. Your timeline is like a mixer. The output from the timeline is one video track and two (or 5) audio tracks.
    [Aaron Elkins] We have 3 separate video clips on each sequence for each angle. How can we have Final Cut export each track individually? Do we need to create a new sequence for each angle?
    I do not understand but you seem to be saying that each of your angles in a multiclip sequence is composed of three separate clips. If that’s the case, you can precompose or nest three individual sequences, one for each angle. Then you can bring the sequences in as the angles into your multiclip sequence.
    But I wouldn’t do that. I’d build each angle as a separate sequence and then export them as self-contained movies.
    [Aaron Elkins] Thanks in advance!
    Umm, sure. but I think we have a translation issue.
    bogiesan
