Activity › Forums › DaVinci Resolve › Best way to append Look Nodes to multiple clips
  • Best way to append Look Nodes to multiple clips
    Posted by Francois Driessen on September 19, 2013 at 9:05 pm
    Hi there.
    What’s the best workflow to append Look Nodes to the end of multiple clip’s node trees?
    I’d rather not use the Track since some footage has been pre-graded with the look already applied.
    Ideally, I’d like to select all the applicable tracks in the timeline and just append an applicable still (that only contains the Look nodes) to all of them – but can’t seem to find a description of this in the manual.
    Any advice?
    Francois
    FireTrigger Inc.
    https://firetrigger.com
    Mike Most replied 13 years ago 2 Members · 1 Reply
  • Mike Most
    September 22, 2013 at 7:59 pm
    If you’re using Version 10, you can do this by saving the look node(s) as a Power Grade. Power Grades can be appended to the existing correction with a double click. This works on either a single shot or a bunch of selected shots, so you can now do what you asked.
