Activity › Forums › Adobe After Effects › best way to accomplish wipe transitions without precomps?
  • best way to accomplish wipe transitions without precomps?
    Posted by Andy Engelkemier on February 11, 2022 at 2:13 pm
    Most of the wipes I’m seeing are using big thick shapes that cover the entire screen. So basically wipe on, then wipe off. That works perfectly for pretty much anything because you just line up the center of that with where you want to transition from one set of things to another, and you don’t have to worry about masking.
    But if you need to mask off a set of layers, and mask On a set of layers, I’m wondering the best/easiest (I know those aren’t usually the same) way of accomplishing that.
    I don’t want to precompose because I am working on projects that have a really short timeline, and precomposing just doesn’t work that well in my head. I’d be totally into it if Adobe let you kind of open up a precomp within the same timeline so you could edit in place more easily, but they don’t, so I only use them when Really needed.
    So what I’m doing now is creating my wipe, with some shapes, and I have one layer that masks everything. Then I just create a set matte to reveal the layers on top. I then copy and paste that to all the layers that need it. Usually, it’s just 2 or 3 text layers, maybe a shape layer or two, and maybe some video footage. So it’s not a Ton, but that method still seems like there’s room for improvement. For one, set matte sucks because it doesn’t work when a layer doesn’t match the comp size. So you either have to precompose that (which creates more work if you need to use expressions, which adds a little time) or I create a solid on top of that, apply the set matte effect to that, and then use that solid as a track matte. That creates even more layers, which I’m not a fan of. I already have a hundred+ layers. I don’t need more if I can help it.
    I’m just wondering if there’s a way to build something in a way that masks footage without having to do that. Maybe there’s a way to mask footage from my mask layer? Like, mask layer 60-66, as a range rather than having to manually add effects to those layers? AE doesn’t have linear A/B effects right? So I’m curious how that would work. I’m sure I’m just missing something obvious.
    Andy Engelkemier replied 4 years, 7 months ago 2 Members · 2 Replies
  • Graham Quince
    February 12, 2022 at 12:14 pm
    I don’t know if it’s the best way, but my method is that I have my transition as a preset with a linear wipe effect, turned off, but saved as part of it. With an expression to control the wipe set up already.
    When I want a transition, I add it from Effects and Presets (which creates a new layer for it), and then I copy the linear wipe to the layer I’m transition to. And then relink the linear wipe’s expression to the transition layer.
    There’s probably a “better” way using Essential Graphics, but this works well enough for me
  • Andy Engelkemier
    February 14, 2022 at 2:26 pm
    Yeah, that’s basically the same as what I am doing as well. I was wondering if you could do it with essential graphics. I can maybe think of one way, but it would only work for transitioning two precomp layers. That would work for premiere, if you’re moving it over there, but I’m keeping things all here, and I try not to precomp when I don’t need to because it just complicates a lot of fast/simple tasks. There are Definitely times I have to, and times I choose to, but it soothes my mind to see everything at once.
