Activity › Forums › Apple Final Cut Pro Legacy › Best Way of Adding an Overall Color Tone in Final Cut 6?
Posted by Sean Duncan on July 15, 2009 at 6:32 pmI am directing / editing a music video for a band and I want to add color tones to the visual – much like the Queen’s of the Stone Age video In My Head (https://www.youtube.com/watch?v=-sTQMy1ErZY). I would normally do this through the color corrector but is there a better way of carrying out such an action?
Thanks for your help – you wouldn’t believe the help that this site has provided to me over the years!
Victor Perez replied 17 years, 1 month ago 6 Members · 7 Replies -
Shane Ross
July 15, 2009 at 6:43 pmWhat’s wrong with doing this through a color corrector? That is what it is designed to do…color the footage. And since this isn’t and “overall” application, but rather clip by clip (each clip has a different tint), it is best done clip by clip. You could add the TINT to each clip, but then it changes the color quality and brightness and contrast, so you will have to adjust that as you go.
Shane
Read my blog, Little Frog in High Def -
Russell Lasson
July 15, 2009 at 6:58 pmYou should open a clip in Color. It’s really a great program for doing…. color.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net -
Victor Perez
July 15, 2009 at 6:59 pmThis can very well be done with the 3 Way Color Corrector. As for an easy way ( if that means not CCing every single clip) probably not. You can do the main grades on the first couple of clips Blueish, Redish, Greenish etc and copy past to other clips in the Sequence per your choosing, but as Shane mentions every clip will most likely have to be tweaked for the best look.
If possible I would prefer Apple Color. Its just my preference.
hope that helpsVictor
Sean Duncan
July 15, 2009 at 10:34 pmThanks for all your responses – I suppose its time to dip my toes into color and if I don’t do a good enough job I will make do with the 3 way corrector.
Again, thanks for taking the time to reply – I just wanted validation that I wasn’t doing something stupid with the edit.
Take care.
Adam Taylor
July 16, 2009 at 12:53 pmwhilst i would reccommend Color for anything colour….there is another method that can give quick results.
Place a Matte Colour onto a layer above your video on the timeline, set it to whatever colour you want, then use the composite blending modes to affect the video. You will get varying degrees of success, but it might be a quick way to alter the look.
You can also reduce the effect the blend has by reducing the opacity of the colour layer.
adam
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UKhttp://www.sculptedbliss.co.uk
Craig Sommerer
July 16, 2009 at 1:36 pmThis is exactly the method I would recommend. Matte layer, composite mode of choice, blend with opacity, done. If the results vary too widely, do a quick base grade with the 3 way first.
I’m amazed at how many times Color and it’s convoluted workflow and sequence prep is recommended when the OP may not have a grasp of the tools within FCP.
Victor Perez
July 16, 2009 at 2:57 pmAlthough Color’s workflow is different from that found inside FCP with its prep work, sometimes major depending on the projects effects, number of slow-mos, stills, etc… It was only when I dove into Color while working on an independent project and watching Walter Biscardi’s DVD on Color that I was able to learn it. And now I use it whenever possible and I believe it makes my projects standout even more.
All the above answers for the question are doable, and I will try the matte layer composite, it does seem much easier than sending to Color and faster when one is in a pinch, but just like FCP there are a number of ways to do an insert edit, some easier and some more difficult. I all depends on your workflow and time constraints.
Victor
