Activity Forums Apple Final Cut Pro Legacy Best way from hd to sd
  • Best way from hd to sd
    Posted by Philipp Hampl on June 5, 2010 at 1:50 pm
    What´s the best workflow if using xdcam HD 422 (shooting with the PDW 700), which will have to be converted to SD (Digibeta) in the end. I want to lose as less of the HD quality as possible, so I think I have 2 or 3 ways:
    1. working native in a xdcamhd422 sequence, then rendering out the finished film, re-import into a apple prores HQ sequence, then play out to tape.
    2. working native in a xdcamhd422 sequence, then copying the timeline into a apple prores HQ sequence, then edit to tape
    3. working in an apple prores seqence form the start.
    Which way will promise to get the best output?
    And: is it better (in terms of quality you´ll get in the end)) to shoot in SD (e.g. IMX 50 MBs)), if you have to downscale it to SD anyways? Is the benefit of the HD-Material all gone (and worse), when I edit and convert it in the above described way or is it still better?
    I know at least the one advantage doing it that way: you have much more possibilities to \”work\” with the material – take the scaling; a disadvantage: when there is SD material within the project, you have to watch out, that you don´t get messed up with all the scaling in the end…
    Regards
    Philipp
    Philipp Hampl replied 15 years, 11 months ago 2 Members · 2 Replies
  • Michael Sacci
    June 5, 2010 at 5:30 pm
    Shoot and edit HD, let your video card downconvert as it is going to the deck.
  • Philipp Hampl
    June 5, 2010 at 5:34 pm
    I am using the blackmagic/decklink Studio2. And I have heard, that the bm-downconverter is not supposed to do a good job.
