Best way from 4×3 to 16×9
Hello all,
I am editing a series of videos that where all shot 4×3, but need to be given to the client to project on a 16×9 screen, and they don’t want anything to stretch. And I guess I should say that I am editing on an Avid Symphony Nitris system (v1.7.7)
What I have done thus far is to edit the piece as a 4×3 with the 16×9 letterbox filter over my video as a reference. Then I duplicate the finished sequence and replace the 16×9 filter with the Pan and Scan filter, setting my source as 4×3, and my target as 16×9. When rendered, this basically creates a zoomed and cropped 16×9 anamorphic video.
This seems to work OK, but since it is going to be projected on a pretty big screen, I want to make sure that I am getting the best resolution possible (considering I am throwing away alot of the original resolution). And I also don’t want graphical elements to get fuzzy.
A colleague suggested exporting a QT Ref, then importing into an HD project, then exporting an SD 16×9 clip (in essence upconverting then downconverting). this will be a very time consuming workflow that I can only afford if it makes a difference. With one test run so far, I don’t see a big difference, although creating a DVD of a few finished projects and watching them on a 16×9 big screen will be the ultimate test.
Sorry for the longwinded explanation, but I just want to know if anyone has any other ideas or techniques that may provide me with the highest quality, highest resolution final product (storage is not an issue).
Mark
