Activity › Forums › Adobe After Effects › best videofootage for working in ae
Posted by Kayak on October 2, 2007 at 1:17 pmhi there,
iKayak replied 18 years, 12 months ago 6 Members · 8 Replies -
David Bogie
October 2, 2007 at 1:51 pmHighest chroma resolution you can afford: DigiBeta, most of the HD formats (not HDV). Understand that most of these require special capture hardware to preserve the signal quality.
bogiesan
Steve Roberts
October 2, 2007 at 3:42 pmSo.
What’s your budget? $1K? $2K? $5K? $20K?
Are you willing to rent?
Are you willing to take time to learn to use something you’ve never used before … such as a complex professional $30K+ video camera?Or would you like to look at DVMatte Pro, which I hear does a decent job of keying DV?
Lifetypo
October 2, 2007 at 3:42 pmWOW!! 115,000$ id have to rob a bank just to even put a down payment on that thing .good lucky with that one kayak
has anyone rented a hdv camera what is the range for a few days of good camera rental
Steve Roberts
October 2, 2007 at 3:49 pmVideoscope in Toronto charges $250-300 per day for an HDV camera. Student discounts are available, and many rental houses offer a weekend rate that matches a one-day rate.
Lifetypo
October 2, 2007 at 3:56 pmthanks steve and dave . renting seems to be the only option at this point .
Alex Harding
October 2, 2007 at 4:40 pmbear in mind that HDV is the same data rate as mini DV with effectively nearly 4 times the pixels… ie 4 times as compressed.
It’s a more modern compression so if you scale it down to SD it might be better than DV, but if you were to decide to work at HD it would be even worse.also, HDV samples colour at 4:2:0 as opposed to 4:1:1, which in some cases could make it worse for keying (i think)
cheers
alex -
Kevin Camp
October 2, 2007 at 4:49 pmthis cow article from a few months ago reviewed a product from convergent design that could take the hdmi out from a hdv camera to capture signifiacantly better video than the recorded hdv signal.
it sounded like a good way to get good quality video from a less expensive camera. and since you’d be shooting in a studio, capturing directly to the computer shouldn’t be a huge issue… although depending on the compression you may need a fast disk array for hd.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW
