Activity › Forums › Adobe After Effects › Best video format for AE CS3 & Final Cut Studio 2
  • Best video format for AE CS3 & Final Cut Studio 2
    Posted by Quincy Hall on April 8, 2010 at 5:51 pm
    I’m fairly new to video graphics but I’m beging to understand the basics…
    My question is: What is the most reliable footage format to use in AE CS3 and Final Cut Pro Studio 2 ?
    I’ve had this problem with AE:
    https://forums.creativecow.net/thread/2/947990
    In addition I’ve not always been able to import video into final cut until I updated my Quicktime.
    I’ve come to the conclusion that your standard jpg encoded .mov is the way to go. Am I right? My software is dated, so I can see my choices are a little limited.
    My stuff is not HD it will just be displayed on a projector for 200 people. I may include some motion graphics, so I’m not sure if that should effect my choice
    I’m using an older machine G5, OS 10.5, 4 gigs RAM duel core. It’s sluggish but works.
    Thanks for the help!
    Quincy Hall replied 16 years, 5 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 9, 2010 at 2:52 am
    [quincy hall] “My question is: What is the most reliable footage format to use in AE CS3 and Final Cut Pro Studio 2 ? I’ve had this problem with AE: https://forums.creativecow.net/thread/2/947990 In addition I’ve not always been able to import video into final cut until I updated my Quicktime.”
    What codec were you using? The problem described in that thread is usually associated with temporally compressed footage, like MPEG2 or H264.
    [quincy hall] “I’ve come to the conclusion that your standard jpg encoded .mov is the way to go. Am I right? My software is dated, so I can see my choices are a little limited.”
    You could use JPG in Quicktime as you mentioned, but it’s lossy. Animation or PNG codecs (in a Quicktime wrapper) are both lossless, and both preserve transparency.
    ProRes might be a good option for you, too — just check out Todd Kopriva’s blog post about preventing gamma shift with ProRes in CS3.
    Walter Soyka
  • Quincy Hall
    April 20, 2010 at 3:45 pm
    Thanks guys. I’m getting started with my project today I appreciate all the help.
