Activity Forums Adobe Premiere Pro Best Video Editing Monitor Output Card
  • Best Video Editing Monitor Output Card
    Posted by Jkm777 on September 28, 2007 at 12:09 pm
    I have been using the Canopus ACEDVio card for a while now. I just use it to connect to my tv for editing. I don’t use the computer screen. The matrox stuff is way too expensive. I need a less that $500 solution. For Vista 64 and CS3, is there an affordable update or method out there??
    Jkm777 replied 18 years, 11 months ago 3 Members · 4 Replies
  • Jkm777
    September 28, 2007 at 4:10 pm
    Since there are no responses, maybe I need to be clearer. When I edit, I look on a flat screen TV that is connected via composite video cable to see the true to life result real time. If there is an easier way, please tell me. Possiibly a simple model change of video card will do this without a Canopus ACEDVio type card???
  • Mike Velte
    September 28, 2007 at 5:08 pm
    External monitor preview with Premiere is Firewire out to either a DV camera with a pass-thru feature and then to your TV…OR to a analog/digital converter, like ADS Pyro A/V link…about $200…more for the Canopus ADVC 100.
  • Blast1
    September 28, 2007 at 10:08 pm
    [jkm777] “For Vista 64 and CS3,”
    Just Curious, is there a reason you are using 64bit software for 32 bit apps?
  • Jkm777
    September 29, 2007 at 8:08 pm
    Yes, for the speed increase of using a 64bit SCSI controller and 64 bit SATA Controller…not to mention the OS that the 32bit app rides on. I know it is debatable, but if the underlying OS is more productive in less clock cycles….it’s handling of multiple threaded 32 bit apps will be more productive. (Faster)
