Activity › Forums › Adobe Audition › best video compression for Audition mixing?
Posted by Nathan Quattrini on January 28, 2008 at 6:19 amI’m using Audition 2 to match mnusic to video. Right now its a large MOV file which won;t play well. Whats the best way to get the video playing smoothly to match music to it?
Stefan Tapper replied 18 years, 8 months ago 4 Members · 7 Replies -
Darren Edwards
January 28, 2008 at 12:06 pmOn our modestly spec’d XP Pro/Audition1.5.1 machine,
we’ve never had problems even with full sized DVAVIs,
but it seems that people with Mac/XP machines running
Audition 2+ are experiencing problems.This isn’t much help, but Audition should have stayed
well away from Apple, and at ver.1.5.1D.
x-gf.com
Willie Toth
January 28, 2008 at 2:24 pmAudirion likes to see an AVI file … Can’t agree with you more about Audition going beyond 1.5 … according to a tech working on 3.0 Adobe was supposed to fix all the problems that 2.0 had … Personally I haven’t had the time to use 3.0 much but what I have seen is that there are some improvments but some of the changes mess with the way I like to edit so I am sticking with 1.5 myself …………. WILLIE
incidental poet
Darren Edwards
January 28, 2008 at 2:43 pmThis 1.5.1 situation reminds of those folks who stuck
– and swore – by Windows 2000. I lot of musos I know
are still using it, probably.D.
x-gf.com
Nathan Quattrini
January 28, 2008 at 4:26 pmI am using a PC. The video happens to be an Mov, doesn`t mean I am on a Mac. My computer is a p4 3.0 ghz with 1 gig RAM. I can use sorenson squeeze to compress the file but I need to know what kind of file is best, and also if there is a recommendation for a computer like mine what will work.
Willie Toth
January 29, 2008 at 6:16 pmYes, AVI is what Audition was designed to work with … WILLIE
incidental poet
Stefan Tapper
January 29, 2008 at 8:08 pmIn my experience lossy codecs like sorenson or h264 with their interpolated I and B frames are rather helpful in Audition.
You should try QT Mjpeg or Animation. Works perfect with backwards scrup and forward playback.
