Activity Forums Adobe Premiere Pro Best uncompressed format for archiving?
  • Best uncompressed format for archiving?
    Posted by Jonathan Shohet on July 21, 2006 at 6:08 am
    I just finished editing an 8 minute film. My source was jpeg time-lapse sequences created on a dslr and converted in combustion to quicktime animation uncompressed, 768×576 pal square progressive (after some color corrections and compositing). There are additional color corrections, transitions and titles done in premiere pro 2.
    I now need to archive the project. I already made a tga sequence + Wav backup, but I want an uncompressed avi\quicktime file as well.
    could you discuss the differences between the various uncompressed options available, and what would yield the best output? file size is not a big issue, I have more than enough disk space. Also, should some sort of 10-bit rendering be considered, even though the source files and the project itself were done in 8-bit?
    many thanks
    Vince Becquiot replied 20 years, 1 month ago 2 Members · 1 Reply
  • Vince Becquiot
    July 21, 2006 at 5:14 pm
    You could use 10 bit uncompressed AVI, but that usually is only needed if animation is involved. 8 bit should be all you’ll ever need.
    Vince
