Activity Forums VEGAS Pro Best tools for notching or removing noise?
  • Best tools for notching or removing noise?
    Posted by Rob Lindsay on May 1, 2015 at 4:07 pm
    Any recco’s for what to use to track down and crush a multi-frequency noise in the track? I am trying Sony’s graphic EQ with some success but I am also muddying the subject’s voice.
    The strange thing is this noise only comes up after rendering. Does anyone here have an idea why?
    8785_lifetimehearingintrovideo.wav.zip
    This is the link to the rendered wav file. It sounds clean alone, but when I put it on a track with picture and rendered it out as an MP4, the noise was back.
    Very weird.All help is much appreciated!
    Russ Froze replied 11 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    May 1, 2015 at 4:14 pm
    It is some type of HARMONIC ring. Do you have the original BEFORE render and SFX-ing?
    Once I zap up the volume it appears. It is a very weird harmonic acoustic anomaly, wh8ich I haven’t heard before now – odd….
    G
  • Graham Bernard
    May 1, 2015 at 4:17 pm
    Are you saying that the RENDER removes your remedy? Yes?
    G
  • Rob Lindsay
    May 1, 2015 at 4:28 pm
    Graham
    No, the noise only appears after render. before render both during the shoot and in Vegas, there was no noise.
  • Graham Bernard
    May 1, 2015 at 4:52 pm
    OK, there is monster noise issue going oin which has been masked by the filter. This is the view of it in iZotope RX 4 Advanced.:-
    Now this is it REMOVED in iZoRX 4 Ad:-
    Here is the Timeline view of the noise. Upper is yours lower is mine.
    I’ve attached MY rendered out sample. I could also clean up and sweeten the audio . . if you wished?
    I think you are using the wrong tool and the render is bringing BACK a harmonic which in turn is muddying the sample . . or the other way around.
    Listen to my “cured” sample.
    Grazie
    8795_lifetimehearingvideo1a.mp3.zip
  • Graham Bernard
    May 1, 2015 at 5:07 pm
    Here’s another sample which I’ve further applied De-clipping.
    8796_lifetimehearingvideo1areduxedclipping1a.mp3.zip
  • Rob Lindsay
    May 1, 2015 at 7:15 pm
    Graham
    That sounds great — thank you for all your help!
    Was this tone something that was only around 20khz or were there freq’s that were in the lower range?
    Since I just tested the same setup with AGC on and off int he same clip and rendered it out, hearing NO noise, I wonder it this may have been caused by more than the anti-AGC tone at 20k.
    What do you think?
    Again, thank you!
  • Graham Bernard
    May 1, 2015 at 9:20 pm
    No, I don’t think it is just the 20. I think that this has developed as a collected harmonic resulting from whatever the EQ tried to make better. This is too complex for me to decipher.
    Grazie
  • Rob Lindsay
    May 1, 2015 at 10:01 pm
    Grazie to you!
  • Russ Froze
    May 6, 2015 at 3:10 am
    Wow, that is one nasty sound up at around 22K, this is what it looks like in Spectral Layers
    As you can see there is a very defined line across the top at around 22K. I know that Grazzie has helped you and done a very nice job of it so thank you Grazzie. My reason for responding is that I am curious as to how this happened to appear in the file. Again I understand it is a question to which you have no answer. To me it sound like a clock or time code generator. Very reminiscent of the old midi clocks used to synchronize sequencers and drum machines. This leads to the question as to which device is at fault. Now I have no idea as to how your audio is routed but it does sound like the camera clock is bleeding into an audio pre amp. I short it’s a ground loop. First I should ask if you are using a separate audio recorder. If so Per chance are both your audio recorder and camera powered from the same source.
    Russ Froze
