Activity Forums Maxon Cinema 4D Best Tool To Close A Complex Mesh?
  • Best Tool To Close A Complex Mesh?
    Posted by Ryan Paterson on May 7, 2014 at 7:03 pm
    I have run into this problem a couple times now but never got around to asking the best way to handle it… I’ve taken a complete mesh of a person and deleted all but the head. I need to close the gaping hole at the bottom of the mesh so I can cut it with Thrausi, what is the best tool to do this with? Workflows, tutorials are welcome, thanks so much
    Darby Edelen replied 12 years, 3 months ago 3 Members · 2 Replies
  • Brian Jones
    May 7, 2014 at 7:10 pm
    depends on how clean the geometry is, if the geometry is correct Close Polygon Hole would be the easiest
  • Darby Edelen
    May 7, 2014 at 11:52 pm
    From your description I’d go for the close polygon hole tool as Brian suggested. If you need a nice clean mesh then you’ll need to use the knife tool to make cuts on the new face.
    Darby Edelen
